Fme 2025 Fanout not working as expected
  • Nov 26, 2025 6:08 AM UTC
  • 5 replies
  • 276 views
f.kemminje
Forum|alt.badge.img+11
I’m using FME 2024 without any issues related to fanout. However, after installing the 2025 version, I’m facing a problem where the fanout is not working as expected. This seems to be a software bug.
I am using a Creator to write shapefiles with folder fanout. Based on an attribute value, the data should be written into separate folders. But currently, it is writing only to one folder ("Low"), while the other two folders ("Medium" and "High") remain empty. Attached test1 fmw file.
The Shapefile Writer is skipping features and showing the following warning message:
β€œShapefile writer: Ignoring feature with unexpected feature type 'High_priority_data'
... Last line repeated 19 times ...”
In FME 2024, this workflow works perfectly and writes to all the folders as expected. I believe others may also be experiencing the same issue in the 2025 version.
Best answer by nielsgerrits
I can reproduce this with a classic writer, but it works fine with a FeatureWriter.
nielsgerrits
Forum|alt.badge.img+67
  • Nov 26, 2025 8:48 AM UTC
jkr_wrk
Forum|alt.badge.img+37
  • Nov 26, 2025 9:27 AM UTC
πŸ‘‡
Forum|alt.badge.img+54
  • Nov 26, 2025 9:49 AM UTC
What version of FME 2025 are you using?
Β
Fanout in writer fails 2025.1.1 | Community
nielsgerrits
Β
The workspace was last saved in 2025.1.3.1. This is what I used to try and reproduce.
DanAtSafe
Forum|alt.badge.img+23
  • Nov 26, 2025 10:44 PM UTC
Hi ​@f.kemminjeΒ and ​@nielsgerritsΒ I can confirm that this dataset fanout problem with the classic writer is fixed in FME 2025.2
