FME 2022.1 64-bit Personal Geodb Reader - Reading feature type as case-sensitive
  • September 13, 2022
  • 6 views
ranga_tolapi
Forum|alt.badge.img+9
FME 2022.1 64-bit Personal Geodb Reader - Reading feature type as case-sensitive. Where as 32-bit Personal Geodb Reader in earlier versions used to read feature type name as case-insensitive.
Is there a way to make FME 2022.1 64-bit Personal Geodb Reader to read feature type as case-insensitive?
Best answer by david_r
A workaround could be to use the SCHEMA reader to get a list of all the feature types in the FGDB, then select the ones you need with e.g. a Tester set to case-insensitive comparison before sending them to a FeatureReader. You'll want to set the FeatureReader to use "Single output port":
imageYou can filter the output by "fme_feature_type" into its respective feature classes.
