Feature Type Feature Class Name and associated writer attributes in FME Desktop 2016.1
  • Dec 2, 2016 10:59 PM UTC
  • 41 views
Hi there,
I'm using FME Desktop & Server 2016.1 with Esri ArcDesktop 10.3.1. The workbench is reading oracle spatial data and writing it into Esri File geodatabases.
In the Shutdown Python Script, I would like to find all the objects in the workbench to determine which are Feature Types, get there Feature Class/Table name and associated writer's destination path & file name.
Once I have this information, I can use Esri's arcpy module (I have already worked out how to import this) to create indexes, etc. on the feature classes.
Thanks
  • Dec 5, 2016 8:11 AM UTC
You can use the special FME shutdown script variables contained in the "fme" module to find the name of every feature class written, see the help: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Configuration/FME_END_PYTHON.htm
Example shutdown script:
import fme
for fc_name, fc_count in sorted(fme.featuresWritten.items()):
    print 'Feature type name:', fc_name,
    print 'Number of features written:', fc_count
Unfortunately the feature type attributes and the writer paths aren't accessible that way.
