Fanning out a feature based groups of a set number
Hi there,
I've been trying to find answers all over the internet, but no results.
In short, I'm generating a CSV output where my input is an unknown amount of entries (workbench will be run several times and input varies each time), but I want to generate a separate CSV for a maximum of 500 entries found.
So as some examples, based on hypothetical inputs, this is the output I want:
350 entries - 1 output sheet
1700 entries - 4 sheets (3 with 500 each and one with 200)
502 entries - 2 sheets (one with 500, another with 2)
I'm not particularly concerned about the order of these features. I tried the ModuloCounter, but instead of splitting up my input per 500, it splits up my input into 500 equally sized groups, which won't do.
Thanks in advance,
Best answer by ebygomm
If count your attributes then you can create a group in the AttributeCreator with the following formula
@Evaluate(@floor(@Value(_count)/500))
Forum|alt.badge.img+40
  • August 10, 2018
@egomm,
Works perfectly, thanks a million!
Best regards,
robotix
Forum|alt.badge.img+10
  • March 11, 2019
I'm trying to figure out how to split a list into smaller segments. I assume this would work the same but I don't understand how you are using the formula. Do you have a visual?
thanks
  • March 11, 2019
thanks
This assigns a common attribute to features so that each group contains a specified number of features (in this case 100) . The common attribute can then be used in a fanout
The workflow to split a list into smaller segments would be quite different.
