Failing to publish workspace to FME server. Error 502
john_esk
Forum|alt.badge.img+7
I get status 502 when trying to publish a workspace to FME-server. The script works perfectly fine when running it locally on my computer. Have tried searching but can't seem to find any helpful information. What could be the problem?
nathanatsafe
Forum|alt.badge.img+9
Hi @john_eskilstuna, thanks for your question.
Has anything changed with your FME Server system? Have you ever had any problems publishing workspaces before? Do other workspaces also fail? If you try to publish the workspace without uploading data as well, does it still fail?
Thanks,
Nathan
xiaomengatsafe
Forum|alt.badge.img+11
Hi @john_eskilstuna, I'm not sure this is the cause of your error, but found a previous Q&A; thread, where user encountered the same error, when publishing from a Newer Desktop version to a Older Server version. What version is your FME desktop?
verdoodtdries
Forum|alt.badge.img+22
Your workspace can get corrupted. Simply try reopening and republishing. If that doesn't work out, try copy-pasting the complete content of the workspace into a new blanco workbench and save this new workspace.
