expose autocad_entity using a FeatureReader
  • Jun 25, 2015 1:07 PM UTC
  • 0 replies
  • 44 views
nielsgerrits
Forum|alt.badge.img+67
Heya FME-cracks,
I recently built a workbench reading a DWG with the AutoDesk reader, expose autocad_layer and autocad_entity, yadayadaydada. Now I want to make it more generic, using a FeatureReader to read the DWG, fed by the Directory and File Pathnames reader.
Problem is: how to expose the autocad_entity attribute?
What I tried so far:
  • AttributeExposer transformer connecter to the Generic output port from the FeatureReader. Nope.
  • Attributes to Expose in the FeatureReader Parameters. Nope again.
  • Additional Attributes to Expose in the AutoDesk reader in the FeatureReader Parameters. Still nothing.
The only result I get is autocad_insert when exploding blocks into entities, but I need all...
The attributes autocad_layer & autocad_text_string are exposed correctly.
Using 64 bit FME 2015.1.0.1 (15480)
Thanks!
Niels
PS My workaround will be using fme_geometry instead, but having a hard time not being able to solve this one.
