Excel Reader - not finding reference cells in IF statements?
  • Apr 19, 2021 12:16 PM UTC
  • 133 views
mlufkin
Forum|alt.badge.img+11
Hi, I have created Excel xlsx files using FME (using a Template and adding values in, for various formulae to use the inputted values to calculate others), and it works really well!
My issue is then when I read that xlsx file back through FME, the formula (IF statements mainly) don't pick up the inserted values! I have them formatted as Numbers in both Excel and FME, and the statement is similar to '=IF(AB8=0,"No Maps",AB8)', which works well when opening in Excel, but every value is 'No Maps' for the above cells when opening in FME! Very frustrating!
I'm running FME Desktop 2020.2.4, 64 bit.
Thanks!
Best answer by simon_maddern
Python solution using the 'openpyxl' and 'excel-formulas-calculator' libraries:
from openpyxl import load_workbook
from efc.interfaces.iopenpyxl import OpenpyxlInterface
import fme
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        filename = FME_MacroValues['ExcelFile'] # Parameter containing the path to the .xlsx file
        wb = load_workbook(filename)
        interface = OpenpyxlInterface(wb=wb,use_cache=True)
        # We're interested in the values in C6/C7 on the Overview sheet, change these accordingly and expose them (if needed)
        feature.setAttribute('C6',interface.calc_cell('C6','Overview'))
        feature.setAttribute('C7',interface.calc_cell('C7','Overview'))
        self.pyoutput(feature)
    def close(self):
        pass
This is fairly slow at around ~30 seconds per cell being calculated, but the only working alternative I could find (using the win32 library) requires Excel to be installed, so would be trickier to get working on FME Cloud/Server.
mlufkin
  • Apr 19, 2021 12:29 PM UTC
Just as an update, I believe the xlsx file is retaining the old value (from the template - i.e. it will say 'No Maps' because the value in the Template was 0) - It's as if the new value is insert by FME, but because it is not opened specifically in Excel, the formaulae are not given a chance to calculate?
simon_maddern
  • Apr 19, 2021 2:28 PM UTC
import fme
import fmeobjects
    def __init__(self):
        pass
    def close(self):
        pass
debbiatsafe
Forum|alt.badge.img+24
Hi @mlufkin​
If you are using Windows and have Excel installed on the same machine as FME, I would recommend trying the latest 2021.1 beta.
Our development team addressed the behaviour you're seeing on Windows systems in FME 2021.1 build 21526+ by refreshing formulas and PivotTables on save. Please note that this fix is limited to Windows system that has Excel installed.
If using macOS, Linux, or Windows systems without Excel installed, then I would recommend using the method suggested by @simon_maddern​
mlufkin
  • Apr 20, 2021 2:53 PM UTC
Hi @mlufkin​
Many thanks!
