Error with Decimal xx.x format ODBC to Hive table
  • Mar 10, 2023 8:01 PM UTC
  • 0 replies
  • 88 views
mferwerda1111
Participant
Any thoughts on the below error, trying to load data into a Hive table that has columns defined as decimal 11,2
Value is 6500, I have also tried stringformatter to 11.2f, and hard coding value to 6500.00, and a few other things like setting the value to double(@Value(my_amount), etc.
Database Error Message: [Cloudera][ImpalaODBC] (370) Query analysis error occurred during query execution: [HY000] : AnalysisException: Possible loss of precision for target table 'xxx.xxxx'.
Expression 'CAST(65000 AS DOUBLE)' (type: DOUBLE) would need to be cast to DECIMAL(11,2) for column 'my_amount'
