Error connecting Geodatabase - Direct Connection
  • Jun 25, 2013 1:20 PM UTC
  • 41 views
Hi dears.
We have a technical question regarding the connection FME using the reader ESRI Geodatabase through the direct connection option.
We are getting the following error message below when trying to connect to the database GIS / Esri.
Opening the Geodatabase reader
 FME has checked out an Esri license. The product checked out is 'ArcInfo'
 Installed ArcGIS version is '9.2'
 Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {Underlying DBMS error[ORA-12545: A conexão falhou porque o objeto ou host de destino não existe
 No extended error.]}
 Please ensure the connection parameters are correct (server=`dummy', instance=`sde:oracle10g:\\;LOCAL=PJTP', user=`UOMSUSER', password=`***', database=`PJTP', version=`UOMSMGR.OMS_DMS_SINC')
 FME Session Duration: 13.2 seconds. (CPU: 0.2s user, 0.2s system)
 END - ProcessID: 2232, peak process memory usage: 77788 kB, current process memory usage: 77524 kB
 Program Terminating
  Could you help with this? Thank in advance.
  Kind regards.
  • Jun 25, 2013 1:39 PM UTC
The error might be same as the issue that this article describes:
Geodatabase Direct Connect returning error
Takashi
