Copy coordinates from a list in a Lat/Long column
  • Nov 6, 2024 6:12 PM UTC
  • 157 views
fme_can_do_it
Forum|alt.badge.img+13
I had a pair of coordinates stored in a single column named "geometry." I used the Attribute Splitter to separate these coordinates and then exploded the list. Now, I have each latitude and longitude in the same column. Is there a way to copy these latitude and longitude values into separate columns labeled "Latitude" and "Longitude" while maintaining the same order?
Best answer by bwn
Separate the List Index integers into Odds and Evens using fmod() in a Tester.
Then can rename it to LONG an d LAT value attributes and merge them back together with FeatureJoiner.
Output from FeatureJoiner
danilo_fme
Forum|alt.badge.img+58
  • Nov 6, 2024 7:38 PM UTC
Hi @fme_can_do_it
Could you share your data?
fme_can_do_it
  • Nov 6, 2024 8:03 PM UTC
Sure! here is the data i read in an excel format in my workspace:
geometry
-97.366166, 32.747101,-97.367519, 32.746789, -97.369184, 32.746717,-97.369023, 32.748890
I have also attached the screenshot of my workspace.
bwn
Forum|alt.badge.img+26
  • Nov 6, 2024 9:11 PM UTC
todd_davis
Forum|alt.badge.img+23
  • Nov 6, 2024 9:28 PM UTC
I went with a GML Approach, as I don’t need to breakup the input at all...just format it. It is because GML has a PosList that allows you to put in space seperate line of coordinates. I am assuming that these are all lines
You just need to update this to your attribute:
And because it is in long/lat, choose 1,2 in the SRS axis in the geometryreplacer. SRS Axis just explains the order or X,Y,Z.
Workspace attached.
