Clipping large raster incomplete result
  • Jun 10, 2024 8:40 PM UTC
  • 154 views
bgeorges
I am trying to clip a ECW raster by a rectangle polygon but the inside output is incomplete. Only a small slice of the ECW is in the output as you can see below.
Is there something I am doing wrong? FME 2023.2
Thank you for your help
bgeorges
  • Jun 11, 2024 12:30 PM UTC
I just have tested with FME 2020.2 and the clipper is working correctly with the large ECW.
Is there a bug with FME Form 2023.2? Anyone can test it?
doko
Forum|alt.badge.img+5
  • Jun 11, 2024 12:32 PM UTC
Could you maybe share some of your data for testing ?
I had another issue with the clipper and raster Data, namely that the Clipper would incorectly clip rasters at the edges.
bgeorges
  • Jun 11, 2024 12:43 PM UTC
I cannot share the ECW because it’s 20gb. I will use FME 2020 to clip a small subset of the raster and see if I can reproduce the problem with FME Form 2023 with small raster.
