Add an attribute to geometry
  • April 1, 2024
  • 62 views
jp12212
Forum|alt.badge.img+4
Hi!
I want to add an attribute to geometry - is this done with the geometrypropertysetter?
For instance, add ‘water  asset’ to a cylinder but not as a layer name rather as an data tag / table.
I ultimately want to be able to bulk add them however am starting with a simple test case.
Thanks.
hkingsbury
Forum|alt.badge.img+55
  • April 2, 2024
AttributeCreator or AttributeManager will allow you to create a new field/attribute
