Silent uninstall for Windows
  • December 11, 2023
  • 347 views
gvatin06
On the documentation website for FME Form, there is a section called "Installing FME Form from the Windows Command Prompt". However, I cannot find any documentation for uninstalling FME Form from the command prompt. Is there any way to do this, so that we can package the uninstall + install for updated processes? Thanks a lot.
hkingsbury
Forum|alt.badge.img+53
  • December 11, 2023
Looking at this thread:
https://community.spiceworks.com/topic/2352381-silent-uninstall-with-no-user-prompt-using-exe-uninstaller
You can look through here: \\HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall
And find the GUID for the version of FME you want to uninstall and then that will give you a uninstall string (using msiexec) which you should be able to combine with the /qn switch to make it silent
gvatin06
  • January 10, 2024
Thanks for your link, but this is not clear at all to me... This thread is not about FME, and I cannot find the software it is about. In your thread, they write about the software "Advanced Monitoring Agent Network Management", which I don't have.
FME is correctly installed with command prompt from the fme-form EXE, but then I cannot find any EXE file for un-installing it. Even in the decompressed temp folder with installation files, I cannot find any "uninstall" file.
hkingsbury
  • January 10, 2024
Correct, but the same process applies for FME. If you read the thread they are trying to do exactly what you're wanting to do. If you apply the exact same logic except search for FME you get a result
gvatin06
  • January 11, 2024
Indeed, I missed the correct part in the answers. Here is the command line I found for un-installation with Windows PowerShell :
Get-Package -Name "*FME*" | Uninstall-Package -Force
