Problems in FME Workbench
mr_fme
Forum|alt.badge.img+9
I'm trying to install the 2018 version of FME on windows 10, but when I run it for the first time, it informs an error and says that it is searching for a solution and then closes itself.
I have already cleaned up the HKEY_LOCAL records on Safe Software .... I reinstalled several times. I'm already an administrator of the machine. Can somebody help me?
  • June 19, 2018
What error did appear? Could you please post a screenshot of the error messages?
mr_fme
  • June 19, 2018
Hi takashi,
This problem occour when I to open the Workbench.
The FME crash when the messagem appear: Checking license....
The FME license assistant crash too...I can´t to open nothing related FME Desktop.
The machine is new...
Thank´s
  • June 20, 2018
mr_fme wrote:
Hi takashi,
Thank´s
I've never encountered such a trouble. Have you checked the "Check online for a solution and close the program"?
If you could not find any solution there, I would recommend you to contact Safe support.
mr_fme
  • June 20, 2018
This problem happens only in FME 2018. I was installed 2017 version and work properly. :( :(
fmelizard
Forum|alt.badge.img+19
  • June 21, 2018
Hi @mr_fme, I'm really sorry to read this! Would you be able to try the latest build?
If you're still having issues with the latest build, please report it to our support team. We would have to investigate why your machine is experiencing this behaviour.
mr_fme
  • June 21, 2018
Hi @TiaAtSafe,
I was tried the latest build already.
The same problem happen.
The problem is ucrtbase.dll.
Thank´s
fmelizard
  • June 23, 2018
mr_fme wrote:
Hi @TiaAtSafe,
Thank´s
ucrtbase implies some Microsoft runtime libs are not installed on your computer. Can you send a screenshot of where you see that ucrtbase is causing troubles? And can you verify ucrtbase is on your computer in an accessible path?
Sorry about this.
