Location of FME Flow system cleanup log files
  • January 16, 2025
  • 21 views
aaron
Forum|alt.badge.img+12
Where can one find the system cleanup log files on FME Flow (2023.2; build 23764)? I’m testing cleaning up a folder under Resources/Temp. I don't see any corresponding logs under Jobs or System Configuration → System Cleanup. Or, is it possible to test a specific cleanup task on FME Flow? I’m currently at the mercy of whenever system cleanup runs, which is vaguely set to once a day at no set time so not ideal for testing.
Best answer by liamfez
Try looking under Resources>Logs>service>current
liamfez
Forum|alt.badge.img+43
  • January 16, 2025
aaron
  • January 16, 2025
Thank you, ​@liamfez. That was the correct location.
