Where can one find the system cleanup log files on FME Flow (2023.2; build 23764)? I’m testing cleaning up a folder under Resources/Temp. I don't see any corresponding logs under Jobs or System Configuration → System Cleanup. Or, is it possible to test a specific cleanup task on FME Flow? I’m currently at the mercy of whenever system cleanup runs, which is vaguely set to once a day at no set time so not ideal for testing.
