I'm trying to license FME using the License Assistant and getting a "FME Not Licensed" error
  • Oct 14, 2016 6:29 PM UTC
  • 133 views
fmelizard
Forum|alt.badge.img+22
keywords: fme not licensed
fmelizard
  • Oct 14, 2016 6:31 PM UTC
Try delete the licenses directory. It's located in your FME install directory. Commonly:
C:\\Program Files\\FME\\licenses
Then run the licensing assistant again.
rylanatsafe
Forum|alt.badge.img+14
You might also have to delete the following directories, if they exist - depending on your version of FME Desktop:
C:\\ProgramData\\Safe Software\\FME\\Licenses
C:\\Users\\<username>\\Documents\\FME\\Licenses
Edit: See also this Knowledge Center Q&A; for a more extensive list and Linux / macOS locations.. https://knowledge.safe.com/questions/36429/where-does-fme-desktop-licensing-assistant-create.html
ponceta
Forum|alt.badge.img+7
  • Jun 14, 2017 6:34 AM UTC
Same problem, same solution thanks!
