I have a FME workspace which converts spatial data from an Oracle database to XML using a XMLTemplator and a XML Validator. With an input of 80.000 features, FME stops in the XMLTemplator with the following error:
unable to realloc 447475646 bytes. Error running translation.
With smaller selections (a few thousand), the workspace works fine. We suspect that due to working in a Citrix Evironment (with Windows 10.1) FME_TEMP should probably be redirected to another drive instead of C:\\ to get enough memory space. How can we change the FME_TEMP variable in Citrix?
Or does someone know other possible solutions we could try?
