FME Service Account Privileges
  • May 30, 2024 3:33 PM UTC
  • 357 views
mcnaughty79
Participant
Forum|alt.badge.img+3
We have a domain account setup to run the  3 services required for FME Server 2022 to function.  My question is simple, does this account need to be apart of the Administrators group?
jkr_wrk
Forum|alt.badge.img+37
  • May 30, 2024 8:35 PM UTC
No, I would not think so.
But your question is not as simple as you think.
I guess you have some issue running something somewhere?
hkingsbury
Forum|alt.badge.img+73
  • Jun 3, 2024 10:19 PM UTC
The FME Flow service account will require read/write permissions to the install location, shared resources and any network drive that may be referenced from processes running.
Depending on your database connection string, it may also require DBO on the referenced database (if using windows auth to connect - I don’t recommend this approach)
