FME license system failure?
  • November 16, 2016
  • 102 views
Hi All,
I am trying to install FME in my system. I got FME trail version key from FME team.
After installation when i try to register my key it displays following error.
"FME license system fiIure: FME is not Iicrid for this mcbin. Coritct your Distributor. ‘tour r9istrtion kj is 0-1 77-567-212. TIi’ SAFE_LICENSE_FILE nc1 LM_LICENSE_FILE rc being ignored byFMIE;ft erLIe t[’iem. setthe envirorimentvrible FME_USE_LM_ENVI RONMENT to the value YES."
How can i install my licence?
Thanks in advance for your help.
Best answer by davideagle
Hi - open the *.fmelic file that you were sent in a text editor, does the registration key noted in the file match 0-177-567-212? If not, either you've applied the license file you were sent to a different machine than the one you requested it for or you've been sent an incorrect license or in rare scenarios your machine has changed its registration key between you requesting the file and applying it. This last issue is rare and would generally have been initiated by something in your hardware changing.
I'd suggest yo re-request a license file for the key 0-177-567-212 from your reseller or Safe direct. All the best, David
davideagle
Forum|alt.badge.img+22
  • November 16, 2016
mark2atsafe
Forum|alt.badge.img+56
  • November 17, 2016
Yes, definitely talk to either your reseller or Safe directly. For Safe use the email address codes@safe.com
