FME Cloud Upgrade
deanhowell
Forum|alt.badge.img+24
Hello I have just upgraded to FME Desktop 2019.1 and am getting a few errors when running a published workspace in FME Cloud.
How is FME Cloud Upgraded? and is it necessary to keep the two in sync?
Best answer by takashi
Hi @deanhowell2009, version of FME Server must be equal or later than the version of FME Desktop with which you create workspaces to run with the FME Server. If the version of FME Desktop is 2019.1, for example, version of FME Server has to be 2019.1 or later.
If the version of FME Server instance in your FME Cloud was 2019.0 or earlier, consider upgrading the instance to 2019.1 or creating workspaces with a previous version FME Desktop (equal or earlier than FME Server).
Check this article before upgrading FME Server instance: Migrating an FME Cloud Instance
  • July 19, 2019
deanhowell
  • July 19, 2019
Thanks @takashi, I will look at upgrading the cloud shortly :)
