Could not load module 'C:\Program Files\FME\plugins\if_func.dll' : 'The specified module could not be found'
  • Feb 12, 2026 8:22 AM UTC
  • 278 views
bianca_
Forum|alt.badge.img+9
Hi everyone,
after using IF clauses in my workspace, I started getting this warning that immediately terminates my translation.
Could not load module 'C:\Program Files\FME\plugins\if_func.dll' : 'The specified module could not be found'.
I tried reinstalling the Microsoft Visual C++ 2015–2022 Redistributables for both x64 and x86  as I saw here on another thread, but that didn’t work. Is there any other solution? Thanks in advance.
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@fazacasbianca! Thanks for sharing the troubleshooting you've done so far! Could you also check if the file exists at C:\Program Files\FME\plugins\if_func.dll? It's possible software (like an antivirus) is blocking this from installing, so it might be worth checking for that as well.
Also, what version of FME are you using? And if you go to the Windows Event Viewer (Windows Logs > Application), do you see any specific error entries (like 0xc0000005)?
I'd also recommend checking out this Troubleshooting Guide for information gathering if you haven't seen it already, and if we can't resolve it here, feel free to open a support case with us here.
bianca_
  • Feb 26, 2026 2:29 PM UTC
hi :) in the end I found a workaround and just not using the if functions anymore. And no, the C:\Program Files\FME\plugins\if_func.dll was not there, which is why I first tried repairing the program and then I tried reinstalling it and it still did not appear. I’m using 2025.2. There were also no specific errors in the Even Viewer, that’s why I was kind of puzzled with it too.
desiree_at_safe
Ah, interesting. Any chance you’re using a third-party DLL for a specific language like Java, C++, or Python? If yes, how was that set that up?
