Zipped mdb error
  • January 21, 2013
  • 15 views
jakethepainter
Just tried to write out to a .zip file for the first time in 2013.  It is a personal geodatabase (mdb).  When I use WinZip to unzip it, I get the following error which causes the unzipping to fail:
Extracting to "C:\\Documents and Settings\\eej2013\\Local Settings\\Temp\\" Use Path: no   Overlay Files: yes For file "AvistaFacility.mdb", the time stamp in the central directory is invalid, using the current system time instead. For file "AvistaFacility.mdb", the time stamp in the local directory is invalid, using the current system time instead. Extracting AvistaFacility.mdb Error:  invalid compressed data to inflate
Anyone else having trouble or know what I'm doing wrong or if there's a bug?
FNE 20130109 - Build 13261 - WIN32
jakethepainter
  • January 21, 2013
Should add - 7zip unzips it just fine.
sigtill
Forum|alt.badge.img+24
  • January 22, 2013
I have had some problems with winzip before, 7zip is more "robust" and can do several other compression methods and standards. Not sure if Winzip supports all of these?
