Z coordinate extraction
  • Nov 20, 2023 8:50 AM UTC
  • 153 views
lazarlubomir
Forum|alt.badge.img+11
Hello everyone! I have dataset with two entities - points with Z coordinates and quite complex multilines. Is there any way how to gain Z values from points to vertices of line? Points have the same XY as vertices of line. Sample below:
imageI have tried the way with SurfaceDraper or with Chopper and PointOnPointOverlayer, but results were not as I expected.
Thank You so much!
Lubo
nielsgerrits
Forum|alt.badge.img+67
I think the SurfaceDraper is the easiest way to do this. What is the issue you encounter?
lazarlubomir
  • Nov 20, 2023 9:08 PM UTC
There were some troubles that SurfaceDraper wasnt be able to enrich some vertices by Z value. But I have invested some time to play with Tolerance and it look many time better :-)
