YearWeek calculation
  • Jan 10, 2018 2:52 PM UTC
  • 137 views
Hello,
What I would like to do is to create a list of all YearWeeks from a given YearWeek till the current YearWeek automatically.
E.g. I would set the beginning to 201743.
Then the output should look like this:
201743
201744
201745
201746
201747
201748
201749
201750
201751
201752
201801
201802
Please note that all weeks should be 2 digits.
Are there sufficient FME transformers to do so or would I need to use Python?
Your help is highly appreciated.
erik_jan
Forum|alt.badge.img+26
  • Jan 10, 2018 3:00 PM UTC
I think the transformer you need is the DateTimeCalculator.
You will need to embed that in a custom transformer to create a loop construction and loop until you reach the current week.
erik_jan
  • Jan 10, 2018 4:00 PM UTC
I have created a workspace that will list the weeks.
You can download it here: weeklister.fmw
  • Jan 11, 2018 4:14 PM UTC
Or the python way:
In a Python Creator and expose the attribute 'YearWeeks'
import fmeobjects
from datetime import datetime, timedelta
class FeatureCreator(object):
    def __init__(self):
        pass
    def close(self):
        startDateText = "201742" # put a start date of a week before needed
        today = datetime.now()
        d = timedelta(weeks=1)
        endDateText = today.strftime("%Y%W")
        Currentdate = datetime.strptime("{}0".format(startDateText),"%Y%W%w")
        # had to add a weekday number to get a datetime value
        CurrentText = "0"
        while int(CurrentText) < int(endDateText):
            feature = fmeobjects.FMEFeature()
            Currentdate = Currentdate + d
            CurrentText =  Currentdate.strftime("%Y%W")
            feature.setAttribute("YearWeeks",CurrentText)
            self.pyoutput(feature)
I don't like putting the week before in (201742) and also having numbers as text but datetime uses string as input and outputs. But it does work
  • Jan 12, 2018 4:29 AM UTC
Although excellent solutions have been provided already, it might also be a good chance to learn FME Date/Time Functions enhanced in 2017. This workflow is an example including use of some Date/Time functions (FME 2017.1+).
