XTMLFragmenter - get specific text
  • December 10, 2024
  • 5 replies
  • 66 views
marta.podsiad
Forum|alt.badge.img+9
I have a html content in _response_body. I am struggling to get only specific text from it. I would like to get only the text highlighted in red.
<b>Layers: </b>
<ul>
<li>
<a href="/arcgis/rest/services/Imagery_Wayback_Ardstaw/MapServer/0">2014/02/20</a> (0)
</li>
<li>
<a href="/arcgis/rest/services/Imagery_Wayback_Ardstaw/MapServer/1">2016/12/07</a> (1)
How can I do it? I assume I should use XTMLFragmenter but I am struggling to get the result I want
Best answer by geomancer
To expand on ​@ebygomm's solution:
The values you want are in an <a> tag that is inside a <li> tag.
When you enter li a[href] under CSS Selector you will get only those values.
Forum|alt.badge.img+43
  • December 10, 2024
If you want the link text this should work
You will then need to explode the created list
marta.podsiad
  • December 10, 2024
it works perfect for the sting above, thanks! How can I change it if there are more items that begins with a href and still select only the text in red
<a href="/arcgis/rest/services/Imagery_Wayback_Ardstaw/MapServer/legend?dynamicLayers=%5B%5D&">Dynamic Legend</a><br/><br/>
<a href="/arcgis/rest/services/Imagery_Wayback_Ardstaw/MapServer/layers?dynamicLayers=%5B%5D&">Dynamic All Layers</a><br/><br/>
<b>Layers: </b>
<ul>
<li>
</li>
<li>
geomancer
Forum|alt.badge.img+58
  • December 10, 2024
marta.podsiad
  • December 11, 2024
How would it look like if I would like to select only the highlighted text?
<b>Display Field:</b> objectid<br/><br/>
<b>Type: </b> Feature Layer<br/><br/>
<b>Geometry Type:</b> esriGeometryPoint<br/><br/>
<b>Description: </b> <br/><br/>
<b>Service Item Id: </b> 4c0f943fb60a4a369104f33d1ad2af4f<br/><br/>
hkingsbury
Forum|alt.badge.img+62
  • December 11, 2024
With that one, i’d look to use a string searcher and regex.
1<b>Service Item Id: <\/b> (.+)<br\/><br\/>
You’ll need to enable subexpression matches
