XMLUpdater path with multiple variables
I'm understanding slowly how to use XQuery but I have come across yet another stumbling block.
I have an XMLUpdater and I want to replace the contents of the following path with some code:
XML Path:
//group[@id=fme:get-attribute("CODE") @category=fme:get-attribute("CATEGORY")]
I'm pretty sure that the above code is not the correct syntax for referencing two variables at once but I can't find any information on how to do this. Any ideas?
Thanks,
Best answer by takashi
I guess what you intend to do is
//group[@id=fme:get-attribute("CODE"and @category=fme:get-attribute("CATEGORY")]
or
//group[@id=fme:get-attribute("CODE"or @category=fme:get-attribute("CATEGORY")]
  • January 27, 2020
or
  • January 27, 2020
or
Perfect!  Thank you @takashi, the AND statement works just as I'd hoped!
