XMLAppender path issues
  • Oct 16, 2019 4:52 PM UTC
  • 10 replies
  • 107 views
Hi community,
I have some problems using the XMLAppender, to define the correct append path in the main xml document.
The main xml document looks something like this:
<DATA>
  <NAME>Features</NAME>
    <CHILDREN>
    <Type>
      <NAME>Boulder</NAME>
      <CHILDREN>
        <Type>
          <NAME>Bouldertype1</NAME>
</Type>
  <Type>
          <NAME>Bouldertype2</NAME>
  </Type>
      </CHILDREN>
    </Type>
    <Type>
      <NAME>Debris</NAME>
      <CHILDREN>
        <Type>
          <NAME>Debris1</NAME>
  </Type>
  <Type>
          <NAME>Debris2</NAME>
  </Type>
      </CHILDREN>
    </Type>
    </CHILDREN>
</DATA>
The xml_fragments have an attribute that define if they are to be appended to Boulder/Bouldertype1 or Debris/Debris1 etc.. and the xml_fragment's looks something like:
<Type>
 <item>round</item>
</Type>
<Type>
 <item>round</item>
</Type>
How do i define the correct path to be used?
Best answer by takashi
Hi, I would use the XMLUpdater with the following settings, rather than using the XMLAppender.
XMLPath: //Type[data(NAME)=data(fme:get-xml-attribute("xml_fragment")//NAME)]
xmlupdater-example.fmwt (FME 2019.1.3)
Result:
<?xml version="1.0" encoding="UTF-8"?><DATA>    <NAME>Features</NAME>    <CHILDREN>        <Type>            <NAME>Boulder</NAME>            <CHILDREN>                <Type>                    <NAME>Bouldertype1</NAME>                    <item>round</item>                </Type>                <Type>                    <NAME>Bouldertype2</NAME>                </Type>            </CHILDREN>        </Type>        <Type>            <NAME>Debris</NAME>            <CHILDREN>                <Type>                    <NAME>Debris1</NAME>                </Type>                <Type>                    <NAME>Debris2</NAME>                    <item>round</item>                </Type>            </CHILDREN>        </Type>    </CHILDREN></DATA>
itay
Forum|alt.badge.img+19
  • Oct 16, 2019 9:08 PM UTC
Have you tried reading the XML document with a XML reader? The reader parameter Elements to match will scan the document and return a path to the selected XML element.
  • Oct 17, 2019 6:21 AM UTC
hi @itay, main xml document contain a large number of nested nodes and elements. As you mention it's possible to scan path to elements on the reader setting level but haven't found a similar approach within any other xml transformer. So path for xml fragments to be appended has to be based on attributed variables (correct me if i'm wrong). Haven't found a solution for this yet but not even sure if i'm using the correct approach..
Is it possible to store the path in a fme_xml_element_path format attribute?
I've seen that the xml id is kept, similar to xml_id (encoded: UTF-16LE): "id-Type-1.3.2"
Can this be used in any way? The xml fragments share the same schema but contain one additional children level (4 level) but the main xml document contain only 3 children. So the xml fragment xml_id value or path to second last level (3) would solve my problem.
  • Oct 18, 2019 7:46 AM UTC
Hi @itay, found out the path can be defined as
 /DATA/CHILDREN/Type{2}/CHILDREN/Type{1}/
the element indexes of 2 and 1 should be able to get from the xml_id
itay
  • Oct 18, 2019 7:49 AM UTC
nice one @andre
  • Oct 18, 2019 12:18 PM UTC
nice one @andre
Hi @itay, the path definition might not be the correct approach.. even if i specify other element numbers it still reverts back to the first element in the nested location.. the path values of {} seems to call on existing lists found in the xml reader
Not sure how to continue now..
  • Oct 18, 2019 2:23 PM UTC
Result:
  • Oct 18, 2019 2:29 PM UTC
Result:
Hi @takashi, thanks for the solution. What if i need to insert the fragments as adjacent siblings or new Childrens? is that also possible by using the XMLUpdater?
  • Oct 18, 2019 2:35 PM UTC
Yes. See the choices in the Update Type column. You can see some Insert methods there.
  • Oct 18, 2019 2:46 PM UTC
Hi @takashi, that solved it! Nice one, thanks a lot..
Now i hope i can load in 77 different type variables that may contain 1400 fragments
itay
  • Oct 18, 2019 3:19 PM UTC
Result:
Hat off to @takashi
