XML transform to table
  • Nov 20, 2020 2:26 PM UTC
  • 117 views
jkr_wrk
Forum|alt.badge.img+37
I have an xml with the following structure:
<?xml version="1.0" encoding="UTF-16"?>
<Report>
<Category>
<Category Empty="10" Name="T" Type="Filter"></Category>
<Category Empty="30" Name="S" Type="Filter"></Category>
</Category>
<Fase>
<Fase Empty="1" Name="AO" Type="Filter"></Fase>
<Fase Empty="2" Name="VO" Type="Filter"></Fase>
<Fase Empty="3" Name="DO" Type="Filter"></Fase>
<Fase Empty="4" Name="UO" Type="Filter"></Fase>
</Fase>
<Imago>
<Imago Empty="1" Effect="Low risk" Score="1" Type="Quantifier"></Imago>
<Imago Empty="2" Effect="Moderate risk" Score="2" Type="Quantifier"></Imago>
<Imago Empty="3" Effect="High risk" Score="3" Type="Quantifier"></Imago>
<Imago Empty="4" Effect="Extreme risk" Score="4" Type="Quantifier"></Imago>
<Imago Empty="5" Effect="None" Score="0" Type="Quantifier"></Imago>
<Imago Empty="6" Effect="Little chance" Score="-1" Type="Quantifier"></Imago>
<Imago Empty="7" Effect="Moderate chance" Score="-2" Type="Quantifier"></Imago>
<Imago Empty="8" Effect="High chance" Score="-3" Type="Quantifier"></Imago>
<Imago Empty="9" Effect="Extreme chance" Score="-4" Type="Quantifier"></Imago>
</Imago>
<Chance>
<Chance Empty="1" Effect="None" Score="0" Type="Likelihood">
<_max_ Max_="6"></_max_>
</Chance>
<Chance Empty="2" Effect="Less" Score="1" Type="Likelihood">
<_max_ Max_="7"></_max_>
</Chance>
<Chance Empty="3" Effect="Moderate" Score="2" Type="Likelihood">
<_max_ Max_="8"></_max_>
</Chance>
<Chance Empty="4" Effect="Most" Score="3" Type="Likelihood">
</Chance>
</Chance>
</Report>
I wan't to transform this to a table like this:
Type|Name|Value
Filter|Category|T
Filter|Category|S
Filter|Category|AO
Filter|Category|VO
Filter|Category|DO
Filter|Category|UO
Quantifier|Category|Low risk
Quantifier|Category|Moderate risk
Quantifier|Category|High risk
Quantifier|Category|Extreme risk
Quantifier|Category|None
Quantifier|Category|Little chance
Quantifier|Category|Moderate change
Quantifier|Category|High chance
Quantifier|Category|Extreme chance
Likelihood|Category|None
Likelihood|Category|Less
Likelihood|Category|Moderate
Likelihood|Category|Most
But the problem is I don't know the names of all the filters and all the quantifiers on forehand.
So I don't know the names of the elements in the xml. I only know they have an attribute Type with a value 'Filter/Quantifier/Likelihood'
I expect that I need to use a XMLXQueryExtractor with this setting:
for $x in /Report
return $x/*/*/@Type
Or something like that
Can someone help me with my workbench?
Best answer by jdh
I'm a little confused by why all the names are Category in your example output. In the example below the Name field is populated by the node name
Type Name Value
Filter Category T
Filter Category S
Filter Fase AO
Filter Fase VO
Filter Fase DO
Filter Fase UO
Quantifier Imago Low risk
Quantifier Imago Moderate risk
Quantifier Imago High risk
Quantifier Imago Extreme risk
Quantifier Imago None
Quantifier Imago Little chance
Quantifier Imago Moderate chance
Quantifier Imago High chance
Quantifier Imago Extreme chance
Likelihood Chance None
Likelihood Chance Less
Likelihood Chance Moderate
Likelihood Chance Most
I tried to do this in an single XMLXQueryExploder but it populated the last element in all the attributes. Separating it into an exploder followed by an extractor worked.
XMLXQueryExploder: /Report/*/*
XMLXQueryExtractor: let $r:= /*
return {fme:set-attribute("Type", data($r/@Type)),fme:set-attribute("Name", name($r)),fme:set-attribute("Value", data($r/@*[2]))}
See attached workspace.
jdh
Forum|alt.badge.img+41
  • Nov 20, 2020 8:14 PM UTC
Type Name Value
Filter Category T
Filter Category S
Filter Fase AO
Filter Fase VO
Filter Fase DO
Filter Fase UO
jkr_wrk
  • Nov 27, 2020 9:22 AM UTC
Thanks, it was my copy paste sloppyness. Indeed I wanted the Name Field to be filled by the Node Name. I noticed you filled the value field with the value of the second attribute. Nice example. I rewrote this so it set the value with the value of the Name Attribute and another attribute with the value of the Filter attribute. But your example made it very clear that the other option was also possible.
jdh
  • Nov 27, 2020 2:40 PM UTC
I did that because on the filter type nodes the value was in the name attribute, whereas the other nodes the value was in the effect attribute, and I didn't want to bother with conditionals.
