XML Templater to read a List
laxmi_2590
Hi Everyone,
I have recently started with FME. I have a case where I have to format an XML from a list.
I am using XMLTemplater Transformer to build a request xml which looks like below
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:wnb="http://sample.com.au">
   <soapenv:Header/>
   <soapenv:Body>
      <wnb:fetchNotificationDetails>
         <!--1 or more repetitions:-->
         <notificationNo>121</notificationNo>
         <notificationNo>131</notificationNo>
     <notificationNo>141</notificationNo>
      </wnb:fetchNotificationDetails>
   </soapenv:Body>
</soapenv:Envelope>
 I am passing some ten notification numbers to a XML templater and they are coming out individually like below
   <soapenv:Header/>
   <soapenv:Body>
         <notificationNo>301</notificationNo>
   </soapenv:Body>
</soapenv:Envelope>
 <soapenv:Header/>
   <soapenv:Body>
         <notificationNo>302</notificationNo>
   </soapenv:Body>
</soapenv:Envelope>
I used a listbuilder transformer and then passed it to XMLTemplater .
What is the option I should select from the below to read a list to form request XML mentioned below
I want a single output from XML templater which looks like below
 <soapenv:Header/>
   <soapenv:Body>
   </soapenv:Body>
</soapenv:Envelope>
Any help would be appreciated. Thanks
Best answer by s.jager
II would solve this by using a creator for the root element, then inside the root element use process-features to get your list of notification ID’s. So something like this:
where the Root Template Expression is this:
<Body>
  <fetchNotificationDetails>
    {fme:process-features("NOTIFICATION_IDS")}
  </fetchNotificationDetails>
</Body>
And the Sub Template NOTIFICATION_IDS looks like this:
<notificationNo>{fme:get-attribute("NotificationID")}</notificationNo>
When I run this, this gives me the following XML Result:
<?xml version="1.0" encoding="UTF-8"?>
<Body>
    <notificationNo>0</notificationNo>
    <notificationNo>1</notificationNo>
    <notificationNo>2</notificationNo>
    <notificationNo>3</notificationNo>
    <notificationNo>4</notificationNo>
    <notificationNo>5</notificationNo>
    <notificationNo>6</notificationNo>
    <notificationNo>7</notificationNo>
    <notificationNo>8</notificationNo>
    <notificationNo>9</notificationNo>
</Body>
Which seems to be what you are looking for. Of course my example is a bit simplifed, you’ll need to include the namespaces and stuff, but this should get you going.
s.jager
Forum|alt.badge.img+16
  • August 27, 2024
<Body>
</Body>
<Body>
</Body>
laxmi_2590
  • August 27, 2024
Hi s.jager ,
Thanks for your response and that really helped. I am able to send  all the notifications in a single call.
Thanks a lot.
May I ask you another query related to response,  I get a response for the above notification request as below
<notificationDetails>
            <notificationStatus>Found</notificationStatus>
            <jobType>SF</jobType>
            <jobDescription>Test</jobDescription>
            <flNumber>110</flNumber>
         </notificationDetails>
            <flNumber>111</flNumber>
            <notificationStatus>Not Found</notificationStatus>
            <jobType></jobType>
            <jobDescription></jobDescription>
            <flNumber></flNumber>
Is there anyway that I can get the output in to rows like below
NotificationNo notificationStatus jobType jobDescription flNumber
121 Found SF Test 110
Is there a transformer I can use to do that ?
Thanks again for your help. :)
s.jager
  • August 28, 2024
I’m not sure what you mean by
You wanted xml, that’s what you get. And you already have the features with the attributes, so that is already in sort of a tabular format. Do you want to see it in the Data Explorer? Then just add an Inspector right in front of the XMLTemplater. Or do you also want an excel or an html table as secondary output?
laxmi_2590
  • August 29, 2024
Hi s.jager,
Thanks for your response.
I want to extract the attributes of the response xml for further processing.
If below is my response xml,
            <jobType></jobType>
 I have to take each one of these notification IDS and respective job type, job desc etc to query another table and get some other information.
121
122
Found
Not Found
SF
SK
Test
Testq
110
112
I tried using AttributeExploder to extract the attribute values. But that is not giving me the expected result,
I hope I made it a little clear now.
s.jager
  • August 29, 2024
Ah, that makes more sense, thank you for clearing that up.
To create features from the response xml, the XMLFragmenter is probably your best option.
