Multi CSV w/ Dual Reader Merging Help
  • May 20, 2025 10:59 PM UTC
  • 213 views
lukeh81
Participant
Hi everyone,
I have struck a roadblock in the creation of a particular FME Workbench that I now require help with. I appreciate your time in advance.
I have multiple csv files that contains a table of data that I would like to process into a single csv file table.
Lines 1-26 of these files contains general information
Line 27 contains headers for a table below
Line 28 onwards contains the data for the table.
In Line 2 Row 2 there is a “cell” (B2) which contains text which I would like to add into a new column in the table repeatedly.
I have done and been able to do the following:
- Used 2 x CSV Readers
- 1st CSV Reader data is transformed down to just cell B1 and B2, with B1 text being replaced with a header name 'Sensor_ID' and B2 simply being the original data in B2 eg. SN_ABC123
- 2nd CSV Reader data is transformed to Line 27 onwards (i.e. just showing the table), plus a few other modifications using AttributeRenamer, AttributeRemover etc.
- Tried using both FeatureMerger and FeatureJoiner to merge the 1st CSV Reader data with the 2nd, such that 'Sensor_ID' becomes a new header for a new column with the data from B2 (eg. SN_ABC123) being populated the full extent of the column.
The problem I have is that when working with multiple CSV files (I sometimes process up to 40) the data from Sensor_ID does not match up correctly with the data in the table. i.e. the wrong Sensor_ID eg. SN_ABC123, with the wrong values in the table.
I am using FME Workbench 2024.1. I have tried joining with FeatureMerger and FeatureJoiner. I have tried joining via a name like FME_basename and FME_Dataset.
I have attached two modified csv files as examples of the raw data to be processed in FME. The output I want is something like in the 3rd file.
Any help would be greatly appreciated.
Thanks,
Luke
Best answer by raghavendrans
​@lukeh81
I am not sure if this idea would be acceptable to you, but still thought of sharing.
The solution is a two step process:
Step 1: Create a lookup csv file containing two columns, first column is the name of the csv file that you are processing and the second column for the Sensor_ID.
For the CSV file name, the fme_basename format attribute needs to be exposed on the Reader Featuretype.
For this step, the workspace will read all the CSV files of interest and create a sensor_id_lookup CSV file.
The output CSV would be something like this:
The CSV Reader would read only the first two lines.
Step 2:
This step involves a CSV to CSV workspace reading from row 27 (header) and 28 (data) with the a Reader FeatureType set to Merge Featuretype
Again, for the featuremerger down the line, the fme_basename format attribute needs to be exposed on the Reader Featuretype.
You will add another CSV Reader for the Sensor_ID lookup.
Then use FeatureMerger to merge based on the fme_basename for the CSV files featuretypes and the csv_name value from the Sensor_ID lookup csv.
The workspace would look like this:
I also noticed that the CSV files contain empty lines like “,,,,,”, which if you need to skip, then you will need to carryout additional checks.
Hope that helps.
Happy FME:-) ing
Cheers
SRG
crutledge
Forum|alt.badge.img+55
  • May 21, 2025 2:41 AM UTC
Hi ​@lukeh81
I would suggest using a workspacerunner. I set up an example of how to set it up. This way you can read through each csv in a folder and then run your processing adding the results to the same spreadsheet (insert).
Test Batch Processing Method 3: Using the WorkspaceRunner – FME Support Center
Hope that helps.
Forum|alt.badge.img+54
  • May 21, 2025 8:39 AM UTC
I would use this sort of workflow, rather than merging
You can use a text file reader to read just the second line and extract the Sensor_ID, keep that attribute and the filepath and send to a second feature reader to read the CSV file from 27 onwards, if you merge initiator and result the Sensor_ID relating to the file will be added to all features.
raghavendrans
Forum|alt.badge.img+28
  • May 21, 2025 9:04 AM UTC
​@lukeh81
Step 2:
Hope that helps.
Happy FME:-) ing
Cheers
SRG
lukeh81
Participant
  • Participant
  • May 21, 2025 2:32 PM UTC
Thanks everyone. I appreciate your responses and will give them all a shot. Regardless of what works best for me, I will have learnt some new FME tricks.
Cheers,
Luke
