Problems with python interpreter
  • May 19, 2025 5:28 PM UTC
  • 179 views
mr_fme
Forum|alt.badge.img+9
I had a script that was running perfectly in FME 2024.1. I upgraded to 2025.0, encountered some issues, and my script stopped working. I then reverted to the previous version, 2024.1. However, my script still doesn't work. When I run it in PyCharm using Python 3.10, it runs perfectly, but in FME I get the following error:
Message Type: fme::internal::_v0::py::Exception
Python Exception <SyntaxError>: invalid syntax (functions.py, line 68)
In the FME options, I have the same paths set as before:
  • PYTHONHOME: C:\Users\XXXX\AppData\Local\Programs\Python\Python310
  • Interpreter: "C:\Users\xxxx\AppData\Local\Programs\Python\Python310\python310.dll"
What could be the issue? Could you please help me?
Thank´s
Best answer by mr_fme
​@hkingsbury,
Thank´s your comment.
My problem was python 3.10 folder, specifically functions.py was corrupted.
I changed my python 3.10 folder to another location.
Works fine!
hkingsbury
Forum|alt.badge.img+73
  • May 19, 2025 7:16 PM UTC
Can you share the script? Everything that’s in the python caller including the default FME stuff.
The error message is saying you have a syntax error on line 68
If its running fine in PyCharm, then that suggests it isn’t correctly written to work in FME. Python in FME needs to be wrapped in specific classes.
https://support.safe.com/hc/en-us/articles/25407578680077-PythonCaller-Transformer
mr_fme
  • May 19, 2025 7:33 PM UTC
​@hkingsbury,
Works fine!
