Concatenate fields with space in between
  • May 12, 2025 8:55 PM UTC
  • 12 replies
  • 505 views
nikkik
Forum|alt.badge.img+8
I am trying to concatenate 6-7 fields to create single field with spaces in-between different field values to create a address like string, no commas needed. Can I do it in text editor?
             Field1  Field2  Field3
original: 123     ABC      Street
                  Filed Combined
 Target:    123 ABC Street
Best answer by alexbiz
StringReplacer should help clean that up :
Don’t forget to type a space character in the replacement text parameter of the StringReplacer
crutledge
Forum|alt.badge.img+55
  • May 12, 2025 10:43 PM UTC
Hi ​@nikkik I think in your case the Aggregator will work well.
crutledge
  • May 12, 2025 10:49 PM UTC
And it would be silly not to recommend the StringConcatenator.😆
nikkik
  • May 14, 2025 3:05 PM UTC
I am using String concatenator but it doesn’t place space between different fields it comes as one string like
123ABCStreet
Thanks!
  • May 14, 2025 3:45 PM UTC
If you are using the StringConcatenator with Basic mode, you can select “Constant” in the String Type column to insert any character(s) including a space literally.
alexbiz
Forum|alt.badge.img+35
  • May 14, 2025 4:04 PM UTC
I personally wouldn't bother with the StringConcatenator. You can just use an AttributeCreator for this :
nikkik
  • May 14, 2025 4:19 PM UTC
issue i am facing is there are nulls in some fields and i am getting unnecessary space in-between how do i solve it so the final field values comes correctly. example below. lots of space between number and street name because field between them have null.
alexbiz
  • May 14, 2025 4:25 PM UTC
nikkik
  • May 21, 2025 1:33 PM UTC
it is removing all the spaces and not just extra.
Thanks!
alexbiz
  • May 21, 2025 1:34 PM UTC
raghavendrans
Forum|alt.badge.img+28
​@nikkik
May be you should consider cleaning up your data using the NullAttributeMapper before sending it or doing the String Concatenation!
Happy FME:-) ing
Cheers
SRG
alexbiz
  • May 21, 2025 1:44 PM UTC
​@raghavendrans Unfortunately this will do nothing, since the spaces are not values of the attributes.
nikkik
  • May 21, 2025 7:59 PM UTC
Thank you for your help everyone!
I got the results I needed, shout out to ​@alexbiz.
