XML Structure using XML Templater
  • Oct 19, 2020 12:25 PM UTC
  • 34 views
nicolae.soare
Forum|alt.badge.img+7
I am quite new to XML and I would like to generate xml structured file using FME.
For input I have a simple csv file with 3 columns:LOCALITATE (tanslation: Locality), STRADA (translation: Street) and NR (Translation: Number).
Desired structure should be something like:
<localitati>
<localitate>Buftea</localitate>
<strada>Parului</strada>
<nr>1</nr>
<nr>2</nr>
<nr>3</nr>
<strada>Independentei</strada>
<nr>4</nr>
<nr>5</nr>
<nr>6</nr>
<localitate>Mogosoaia</localitate>
<strada>Printipala</strada>
<nr>11</nr>
<nr>12</nr>
<nr>13</nr>
</localitati>
I used FME to read my CSV, added an XMLTemplater to obtain my desired xml.
After I properly(maybe?) set all parameters, it doesn't seem to group NR by STREET. Instead, it is placing all numbers for each street in each Locality.
I attached workspace + input and output data.
Can you give me some help in telling me where I am making the mistake?
Thank you!
nicu
jkr_wrk
Forum|alt.badge.img+37
  • Oct 19, 2020 2:04 PM UTC
I think what you are looking for is the SUB-template, combined with the "group sub features by" setting.
Maybe you need to do this for every layer of data. So two xmltemplaters: one for the 'street' and one for the 'locality'. But I did not look at your workbench or data. So maybe I'm wrong.XML Sub Templater
I hope the image above will give you a clue to figure it out?
