Writing ffs to pdf
yomi
Hello FME family,
I am new in using FME and I really want to learn more about the software.
I have FFS table that I want to write in PDF. Also in the PDF output, I want to show the number of time a feature (string) occur in one of the attribute columns.
I will appreciate a tip on how to go about it because I have tried all I know but not working.
Thank you.
yomi
  • March 28, 2020
@daleatsafe could you please help me, Thank you
jovitaatsafe
Forum|alt.badge.img+11
Hi @yomi,
Thanks for your question! Is your FFS table an FME Feature Store file? Have you given it a try reading it in with the FFS reader and writing out to PDF? Hitting Generate Workspace in FME Workbench is a really great place start if you haven't already. And if you have, may I ask what problems you're running into? Please feel free to share a sample dataset and your workspace so far. I believe you may want to use a Tester transformer to see if the column contains the string you're looking for.
I also wanted to mention that we have a lot of free learning resources including free training, both live online and recorded if you wish to take advantage of that.
yomi
  • April 2, 2020
@jovitaatsafe thank you for your response. I have used TableAdder to prepare it.
