Writer with removed empty columns, based on feature
  • Mar 31, 2022 7:58 AM UTC
  • 198 views
superjets
I have a huge dataset and I want to make writers based on type. Some types have only 1 samples, some have 100, and I would need to remove all empty sample-columns from all writers. There are over 100 types, so manual work is out of question.
I have tried to use NullAttributeMapper and set all values to missing, but how to drop them before writer?
mark2atsafe
Forum|alt.badge.img+59
Yes, you can do this with the new-ish SchemaScanner transformer. I picked this as my question-of-the-week and made a video of it that you can find here: https://www.youtube.com/watch?v=QB3LXE9ycp0&t=562s
Basically, you scan the schema making sure that missing attributes are left out of the new schema design. That schema is fed into a dynamic writer and provides the basis for writing out data with only the required attributes.
The video explains better though!
superjets
  • Apr 4, 2022 9:17 AM UTC
Hello Mark!
And thank you sir for your excellent answer, it really solved my problem.
I have one question though, can this be done with Excel-writer too?
I tried with the same fanout options, but it did not work. Csv is okay too, but xlsx would be preferred if possible.
I post this solution here for future reference for myself and others in need:
imageScemaScanner
imageCSV Writer:
