Write to AutoCAD Civil 3D
  • Feb 22, 2024 9:46 AM UTC
  • 118 views
galigis
Forum|alt.badge.img+22
Hi All,
Is there any writer for AutoCAD Civils 3D (.dwg)?
There’s definitely an AutoCAD Civils 3D and Autodesk AutoCAD Map 3D Object Data Readers but can’t find the same writers?
Best answer by itsmatt
At this point I don’t think there is a specific write for Civil 3D - you can try and just use the ACAD or REALGWG writer though and see of this gives you the results you’re after.
there is though a Map 3d Wirter: Autodesk AutoCAD Map 3D Object Data Writer Parameters (safe.com)
itsmatt
Forum|alt.badge.img+48
  • Feb 22, 2024 9:54 AM UTC
