Write timestamp (datetime) with MS SQL JDBC Writer
  • Jul 20, 2021 7:51 AM UTC
  • 128 views
so_much_more
I cannot understand why I get the error message
MS SQL Server Spatial (JDBC) Writer: Error writing feature. Error: Attribute 'DATECOLLECTED' does not contain a valid timestamp
The timestamp I want to write is for the moment hard coded as 2021-07-20.
The databse accept this format confirmed with successful update SQL
update dbo.Feature
set "DATECOLLECTED" = '2021-07-20'
where ID = ...
Why does FME fail to write to my db? Any suggestions?
Best answer by philipwhitten
Hello @so_much_more​, What is the data type of the field? Is the data type date or datetime? You might need to add a time to your string.
kailinatsafe
Forum|alt.badge.img+24
Hello @so_much_more​ , is the writer returning an error at all? Have you tried manually setting a value? Or setting the value with SQL? Best, Kailin.
philipwhitten
Forum|alt.badge.img+15
  • Jul 20, 2021 11:42 PM UTC
so_much_more
  • Jul 21, 2021 10:53 AM UTC
The datatype is datetime. as @philipwhitten​ mentioned what was missing is to also add time to the string.
So after adding "00:00:00" to the date it worked fine.
I assume SQL Management studio throw that on itself if its missing to match the datatype in the database.
so_much_more
  • Jul 21, 2021 10:54 AM UTC
Error from writer was my message "MS SQL Server Spatial (JDBC) Writer: Error writing feature. Error: Attribute 'DATECOLLECTED' does not contain a valid timestamp". I just needed to be a bit more verbose and specific adding time to the record "2021-07-20 00:00:00"
