WorkspaceRunner - return values?
  • Aug 25, 2026 7:11 PM UTC
  • 68 views
datablue
Forum|alt.badge.img+11
I have a workspace that creates a CSV file from an ArcGIS feature service. I have five attributes that contain 0 to 5 comma-separated 5-digit integers. I sort the integer list then look up text values in an Excel file. I’d like to put this task in a separate workspace and call it from a WorkspaceRunner. For example, I convert “12345, 12346, 12347” to “Desc1,Desc2,Desc3”
I have a programming background and was thinking of a WorkspaceRunner as a function or sub-routine with a return value. I understand how to pass a parameter to a workspace, but how do I get a return value (e.g. “Desc1,Desc2,Desc3”) back to the parent workspace? I have a feeling that I’m misunderstanding what a WorkspaceRunner can do. Thanks.
Best answer by veronikaatsafe
Hi ​@datablue,
You are on the right track with your answer, as the WorkspaceRunner only outputs process metadata (_proc_count and _processes{}) and does not expose any features or attributes generated inside the child workspace. Using a custom transformer would be similar to using a function call, so it should be the right tool for your purposes.
You may find these resources helpful:
Creating a Custom Transformer — FME Documentation
Exporting a Custom Transformer — FME Documentation
Output attributes of a WorkspaceRunner — Community Post
If you have any other questions, please let me know!
datablue
  • Aug 25, 2026 9:47 PM UTC
I will answer my own question here.
I believe that I need to use a Custom Transformer and not a separate workspace. This will allow me to return a value. I do need to figure out how to export a custom transformer so that I can use it in other workspaces.
veronikaatsafe
Forum|alt.badge.img+13
Hi ​@datablue,
datablue
  • Aug 26, 2026 10:22 PM UTC
Hi ​@demyanovaver,
Just yesterday I got my first custom transformer working. It’s a powerful feature. I plan to export it and use it from multiple workspaces. Thanks for your message and links.
