Workspacerunner fails to find published parameter
  • Jul 17, 2024 1:20 PM UTC
  • 222 views
wrijs
Forum|alt.badge.img+5
Hi there,
We recently installed ArcPro 3.3 with the data interoperability extension FME version 2024.0.1.0.
I have succesfully used WorkspaceRunner in the previous version of ArcGIS PRO 2.8.
But now, when I use the WorkspaceRunner transformer to run a simple workspace the transformer fails to read the published parameter, it says "Specified workspace has no parameters or could not be read".
The workspace I am loading into workspacerunner does have a published user parameter.
Does this happen because of the new version of ArcGIS? Anyone else have this experience?
Thanks,
Winonah
saraatsafe
Forum|alt.badge.img+13
  • Jul 18, 2024 5:39 PM UTC
Hi @wrijs,
Does the workspace you’re loading run normally (without the WorkspaceRunner)? Are you able to run it without the user parameter, and if so, does that cause any issues?
wrijs
  • Jul 19, 2024 11:11 AM UTC
Hi @saraatsafe , the workspace runs normally when I run it with the default values of the parameters.
spatialexjames
Forum|alt.badge.img+10
I’m also seeing this after an upgrade to FME 2023.1 (data interop version). The workaround I have found is to re-create the workspace it is pointing at: go into that workspace, select all (ctrl + A), and copy into a blank workspace, then save over the original workspace name and it should sort it.
