Workspace Spanning Database Transactions
  • Oct 23, 2019 9:09 PM UTC
  • 142 views
At the most basic level, I am looking for a way to
1) execute a stored procedure
2) execute a multi-step process that populates multiple database tables
3) executes another stored procedure
on MS SQL Server, as a single transaction. Setting "a very large transaction interval on your database writer" is not really a good answer; it is not a guarantee. See this answer
Technically, step 2 would happen only if the result returned from the stored procedure in step 1 indicated it was safe to. But one step a time; I need to figure this part out before that becomes relevant.
Is there a way to have a database transaction span a workspace, or some subset of it?
See this related question and my comment there.
Note: Getting FME to call a stored procedure was actually pretty straightforward, even for this FME n00b; it is the environment in which it needs to happen (a single transaction) that is proving bothersome.
@pakicetus You might be able to use fme_db_transaction. This obscure database functionality is documented for each database format that supports it. i.e. SQL Server. To use fme_db_operation:
  • Set Bulk Insert = No (Bulk Insert = Yes ignores triggers and constraints)
  • Set the Features per Transaction = 0 (this enables the fme_db_operation mode)
  • Set the value of fme_db_operation to one of the documented values: COMMIT_BEFORE, COMMIT_AFTER, ROLLBACK_AFTER or IGNORE
The trick is: how to order the features. This depends on the data your reading. In the attached example I used Sorter and the Set Connection Runtime Order to ensure that the data is grouped together and so the parent / child tables get written in the right order . An alternative is to use SQLExecutor with a WHERE, the Results for each 'where' and Initiator are returned together. FeatureHolder sometimes works.
Example workspace (2019): databasetransactions2019.fmwt
