WKB to SDO_Geometry not working correctly with "Multipolygons"
thomastupuivao
I have a "mapinfo" table that I'm trying to load into a oracle DB with SDO_Geometry. My license doesn't let me create a writer in FME as an Oracle Spatial table. So my workaround is to add the tables as "oracle non-spatial" tables. This works fine for address points but when I run the following SQL;
This updates successfully. The issues is when I check in "Data Inspector" if its saved correctly (for this particular record which is a multipolygon).
I get only one of the polygon objects returning;
Best answer by steveatsafe
Hi @thomastupuivao,
Could you try this SQL instead?
UPDATE test_postcode SET geoloc = sdo_geometry(wkb,335872);
steveatsafe
Forum|alt.badge.img+12
  • March 26, 2020
Hi @thomastupuivao,
thomastupuivao
steveatsafe wrote:
Hi @thomastupuivao,
hi @steveatsafe, that worked!! thanks for that! appreciate it.
steveatsafe
Awesome!!
steveatsafe
@thomastupuivao,
A couple of other things for your Oracle Database:
Make sure spatial_vector_acceleration=true.
What database release are you running? You might want to see if you are on the latest spatial merge patch.
Also, in case you didn't know - Spatial and Graph is now included in the database at no extra cost (as of Dec 2019).
