Why is the xml schema written to the first tag coming out of the XML Formatter and how do I stop it?
Here is a screenshot of my XML Formatter:
and this is the Output:
<CABS_EINGRIFF xmlns="http://schemas.webs.idu.de/cardo3/Ikx/IkxBase">
<EINGRIFF_EINGRIFF xsi:nil="true"/>
<EINGRIFF_INDEX xsi:nil="true"/>...
Why does the first tag get all the schema information added to it and how can I stop FME doing it?
  • April 23, 2018
Have you set "Write XML header" to False in the XMLTemplater (I'm assuming you're using one)?
This is set to "no"
  • April 25, 2018
robertdbuckley wrote:
This is set to "no"
Can you post a sample workspace here that reproduces the issue?
