Why is the geotiff reader not picking up the location?
  • Jan 17, 2019 5:30 PM UTC
  • 10 replies
  • 249 views
I have a geotiff (sentinel-1 SAR) that i can view correctly in ArcGIS. It shows in ArcGIS properties as being GCS_WGS_1984. If I read it in FME and write to another tiff it is also fine. But within FME it seems to lose the geographic contect and switches to Coordinate system: unknown and in the inspector displays as if the pixel values are geographic coordinates. This means that I cannot perform any geographic operations on it (I plan to use rasterextentcoecer and mapnik).
Is this an issue with my reader, or can I reintroduce the location? The tiff has no world file so I dont actually understand where the georeferencing is stored - but arcgis can read it.
Forum|alt.badge.img+63
If it's a GeoTiff the georeferencing is stored in the file's header. FME should be able to read that, what do you see if you use a GeoTiff reader and then direct it to an Inspector?
  • Jan 18, 2019 10:01 AM UTC
In inspector it displays but from 0,0 in the top left corner and the map displays with unknown coordinate system and unknown units. This matches the properties at the top but down in the IFMERaster bit it seems to have the coordinate system and control points but is just ignoring it
If you send it to an Inspector and have a background map showing in the Data Inspector, does the GeoTiff show up in the right location?
  • Jan 18, 2019 11:53 AM UTC
the background map doesn't appear to be loading at the moment but previously no its huge and anchored to null island extending south and east
That definitely sounds as something wrong with the georeferencing or coordinate system (and something that shouldn't really happen within FME). You can try adding a CoordinateSystemSetter to your workspace to specifically set the coordinate system to LL84
mperry
Forum|alt.badge.img+9
  • Feb 25, 2019 3:09 PM UTC
Hi there,
Also having the same issue here. Geotiffs are loading in ArcMap properly but not in FME. If you use the CoordinateSystemSetter it will force the image to the coordinate system but the origin will still be 0,0.
Hi there,
Can you share (a small version of) one of those tiff's here?
mperry
  • Apr 7, 2019 11:41 PM UTC
Hi, please find here:
Extract_tif3.tif
rahulsharma
Forum|alt.badge.img+12
Extract_tif3.tif
@michael.perry5, FME rely on Geotiff world files or the information in the header to get coordinates.
*.tif.aux.xml are auxiliary files that ArcGIS uses to read coordinate system, Currently we do not suppor this but will be adding support for future releases (http://desktop.arcgis.com/en/arcmap/10.6/manage-data/raster-and-images/auxiliary-files.htm )
Can you make a copy of your existing world file and rename the extension to *.tfw and try again using FME?
We only guess the world file extension that has w at the end so anything with *.tifw or *.tifw or *.tiffw or *.wld
Forcing the coordinate system will not work and it needs the GCPs(ground control point) which should be stored in the world file.
mperry
  • Apr 29, 2019 12:59 AM UTC
Hi rahulsharma, thanks very much for your reply. Very helpful.
Regards
