. Which transformers that I have to use to get what I want ?
  • Sep 30, 2019 8:05 AM UTC
  • 7 replies
  • 90 views
I would like to insert a table into a pdf. Indeed, I extract datas from a Excel table.
I have used PDFpageFormater. However, it seems that only picture are allowed to appear in the pdf. Which transformers that I have to use to get what I want ?
Thanks for your help
Forum|alt.badge.img+63
There is a TableAdder custom transformer that you can try.
  • Sep 30, 2019 9:13 AM UTC
I tried this transformers. However, I cant get a table but a ligne. Can you propose me some parameters for this transformers ?
Can you share your workspace and data? That'll make it easier to make some suggestions.
  • Sep 30, 2019 9:27 AM UTC
I get those datas from several Excel tables. Then I have to return those into PDF.
It looks like the TableAdder could do with an upgrade, I can't seem to get anything useful out of it either. @daveatsafe, it appears you were the last to work on it, can you suggest something?
daveatsafe
Forum|alt.badge.img+24
  • Sep 30, 2019 6:28 PM UTC
Hi @mika,
I will take a look at the TableAdder transformer, but I think you will get better results from a combination of two transformers:
- HTMLReportGenerator - this is a powerful transformer that can build quite a complex report, including tables, from your data
- HTML2PDFConvertor - use this instead of the PDF writer to convert your HTML report into a PDF file. This is an FME Hub transformer.
gio
Forum|alt.badge.img+15
  • Oct 2, 2019 3:07 PM UTC
This is what I use for all my tables in rasterwriters and pdf writers.LDN from dwg.pdf
(alas annotations bit Dutch, larded with some English)
Not added sorting and fontcalculation yet. So I have a "Multiplier breedte" (breedte is width to fit your chosen font manualy).
The parameter "Attr_participants" is a comma separated string of the attributes you use. So do not enter attributes. ( or enter them and remove the @Value() bit).
I think it is a interesting way of doing it.
Tabel messing ... again.fmwt
The pdf inserted is created with the Tabel2 transformer directly from the data, a AutoCAD file.
Just honor the creator. ;)
