Where is FME headed with the CS-Map projection library?
  • Oct 16, 2019 8:35 PM UTC
  • 81 views
fmelizard
Forum|alt.badge.img+22
There seems to be a trend moving away from the CS-Map projection library and I'd like to know where FME is going with it as well!
Best answer by jovitaatsafe
As there is no longer an active community supporting CS-MAP, we're aiming in the future to look into the Esri reprojection library and PROJ. That being said, we will still continue to support CS-MAP as we know that a lot of FME users still depend on it. So we will work to make it easier and easier to use either PROJ or Esri (or CS-MAP) as the default projection engine in FME with time.
There's also a PROJReprojector currently under active development with a limited form of it available already in the FME 2020.0 betas. If any keeners out there are interested in trying it out, you can find it in our downloads/betas page.
jovitaatsafe
Forum|alt.badge.img+11
  • Oct 16, 2019 8:36 PM UTC
