WHERE clauses in FME
Hello,
I am a basic user of FME and have created a workbench merging many tables. I need to add a further table, but before I use the FeatureMerger I need to specifiy a WHERE clause on the reader. I have tried doing thison the reader with no joy. I have also tried with the FeatureReader and no joy. I cannot find any help documentation in the reader to help me with syntax. Is there a simple transformer I can use?
I need a very simple clause to pass only certain attributes from one of the fields into the next transformer.
Can someone assist please?
Harriet
owen
  • June 14, 2013
Hi Harriet,
I think it needs to be a format that supports querying, like a database.
Alternatively, you could use a tester
Owen
  • June 14, 2013
Hi Harriet,
You can use general SQL syntax for the WHERE Clause. For example: num = 100 country = 'Japan'   Naturally, relation operators (<, > etc.) and logical operators (and, or) also can be used.
Takashi
Hi Harriet,
you could give the SQLExecuter a try and here is more information about SQL.
http://www.w3schools.com/sql/sql_where.asp
Best regards,
Stefan
  • June 14, 2013
Hello,
Tester! Yes it worked perfectly! I knew it must be simple! Thanks very much guys!
  • June 14, 2013
if you have lots of data in your table and you only use a small part, be aware that the Tester will me much slower and will consume a lot more memory than a proper where-clause, as FME will have to pull all the data to your desktop, rather than letting the database filter it for you at the source.
If you post your where-clause here (as well as the type of reader it is), we might perhaps be able to help you using it.
David
Forum|alt.badge.img+4
  • August 18, 2015
@Takashi, every time I Google a question about FME, this Knowledge Center is almost always one of the results, and you are almost always the one with the answer. Thanks for your contributions!
davidmooney
Forum|alt.badge.img+5
  • February 25, 2022
Smallworld 4/5 Reader
Here is some documentation for anyone who has the same question but is using a Smallworld 4/5 Reader.
Example: I want to read records from the collection named eo_power_xfrmr_inst with a device_type of "Underground"
WHERE clause: [Electric]eo_power_xfrmr_inst WHERE device_type = "Underground"
General formatting: [Dataset]<collection_name> WHERE <field_name> = "???"
