When translating to SDE using SCHEMA_FROM_TABLE, is there no way to assign attribute Name aliases?
  • Sep 15, 2017 9:24 PM UTC
  • 65 views
I have my SDE destination schema in a file. But I don't see any parameter for Attribute Name Column Alias. So I'm guessing there's no easy way to assign Attribute name aliases. If I'm wrong, would love to learn how to do this.
Best answer by fmelizard
Hi @ieukcoca, aliases are normally manually set through transformers such as the AttributeManager (see: Working with Geodatabase Field Alias). That being said, the AttributeManager does have an Import option which may help lessen the manual toll of creating numerous aliases.
fmelizard
Forum|alt.badge.img+22
  • Sep 22, 2017 4:40 PM UTC
