When I Working with IFMEPolygon and IFMEMultiArea encounter some trouble
  • May 10, 2018 3:18 AM UTC
  • 10 replies
  • 248 views
I create two ploygon,one is IFMEPolygon,the other is IFMEMultiArea (2 Parts). After that, work with the Extruder transformer, but only the the polygon of IFMEPolygon had been extruded, what can i do to help it ?
  • May 10, 2018 3:43 AM UTC
Hi @keplerleee, the Extruder creates a MultiSolid from a MultiArea generated by the Clipper, but the resulting MultiSolid cannot be transformed to either a CompositeSurface or a MultiArea with the GeometryCoercer. If you set 'No' to the Create Aggregates parameter in the Clipper, it would decompose aggregates into individual parts (non-multi areas) before outputting.
  • May 10, 2018 4:03 AM UTC
Thank you very much. I encountered such a situation while doing other work, so I wrote this example.When I stretched polygons, I encountered a MultiSolid type. These geometry can not be stretched into a three-dimensional body, but just a three-dimensional surface, so I asked this question.I also need your help to solve this problem
  • May 10, 2018 4:11 AM UTC
Have you set 'No' to the Create Aggregates parameter in the Clipper and run?
  • May 10, 2018 4:19 AM UTC
Yes, it's already set up, and it's working.
Please wait a moment, I will do another example to show you.
  • May 10, 2018 4:24 AM UTC
solidtest2.fmw
test.zip
  • May 10, 2018 4:25 AM UTC
In fact, what I encountered was the data of a shp file with MultiSolid,that can't export to 3D body.
  • May 10, 2018 10:11 AM UTC
The condition is different from the original question, but the theory is the same. You can just insert the Deaggregator between the Extruder and the GeometryCoercer to decompose the MultiSolid into individual solids (Extrusion). Alternatively, you can also insert the Deaggregator before the Extuder to decompose the MultiArea into individual polygon before extrusion.
  • May 10, 2018 12:00 PM UTC
Thanks,I don't want to use this Deaggregator because I want to keep this MultiArea type and let it work with the Extuder.
  • May 10, 2018 12:07 PM UTC
No way unless you de-aggregate the multi geometry. A workaround is, use a Counter to add temporary ID to each feature, Deaggregator, Extruder, GeometryCoercer x 2, then use the Aggregator (Group By: the temporary ID) to restore the multi.
  • May 10, 2018 12:32 PM UTC
Sorry, I was wrong. There is a way without Deaggregator. Try setting this Test Clause to the Geometry XQuery parameter in the first Geometry Coercer.
This part  Geometry Type  =  IFMEExtrusion
