When I am trying to open GPKG file, I am receiving the following error: Workspace generation failed. Parameter file was C:\\Users\\MITINA~1.UPW\\AppData\\Local\\Temp\\FME_1695313458867_14324. I have tried reinstalling the software.
  • Sep 21, 2023 4:32 PM UTC
  • 85 views
evieatsafe
Forum|alt.badge.img+28
  • Sep 28, 2023 12:10 AM UTC
Hi @mitinaupwanshi​ this is a concerning issue. I have some questions before someone may be able to help you:
  • What version of FME are you using?
  • Have you tried opening FME Workbench or Data Inspector (without opening a file)?
  • Could you share your Windows Event Viewer log?
  • Could you share your full log file?
You can also create a case if this is an urgent matter here: https://community.safe.com/s/submit-case
